Detailing tip of the week
im thinking....people need to know simple tips on how to clean there cars and stuff...specially girls...so ill do this on a weekly basis... anyone with a tip is happy to jump on board...
TIP OF THE WEEK: Maintianing your wheels finish while mazimizing shine is easy. Start by cleaning wheels first. Applying a quick coat of Smartwax RIMWAX bi-weekly will help reduce brake dust by 50% while enhancing and maintianing your rim and wheel finishes for years to come.
Detailing tip of the week: reason why a microfiber towel has two sides is because one side its for applying a product and the other to buff the product off. that's why always be picky about the towels you buy and what you use them for...
ANOTHER GREAT TIP FOUND IN A DIFFERENT FORUM.
Proper detailing towels will make any detailing job a breeze, SmartWax recommend high grade microfiber towels with 70/30 blend like our Monsters Towels 16x16, http://www.smartwax-usa.com/ProductD...de=MIC_1100_03
Detailing tip of the week: when fully detailing the exterior of your car (wash,clay,seal,glaze,wax) you should be using 6-12 towels min. preferable double sided microfiber towels with silk trimming - https://www.smartwax-usa.com/Product...de=MIC_1100_01
detailing tip of the week: "for those that do car shows or just simply want to use no water to clean your rim & tires on the spot, we have a solution...use any citrus base product like carpet cleaner or smartcarpet blended with water on the rim & tire, wipe off with a microfiber towel to a perfect clean surface" apply more if needed. this process is good on any type of finishes.
DETAILING TIP OF THE WEEK: how to correctly use a microfiber towel.
1- evenly spray smartdetail across your surface.
2-wait a sec for the formula to work
3 & 4- folding the towel in four,wipe side to side moving down in one direction.
5- turn tow...el around to avoid the captured dirt to scratch your surface.
6- wipe gently side to side for a silky shine finish (7)!
Rob944
09-30-2008 03:26 PM
