Product Review: Wolfgang Cockpit Trim Sealant
By TroyScherer
Product Description / Claims:
Seal and protect all interior surfaces with one product!
Now you can keep the interior of your car looking and feeling new with a single product that’s incredibly quick and simple to apply. Wolfgang Cockpit Trim Sealant is an invisible, advanced synthetic polymer coating that provides a durable coating of protection and beauty to all leather, plastic, vinyl, rubber, wood and metal interior trim! Wolfgang Cockpit Trim Sealant replaces the need for multiple products!
Product Details:
Packaging: Typical Black Wolfgang Bottle with a sprayer
Directions: Yes
Color: Clear
Scent: Mild Chemical
Pricing: $29.99 @ 8oz / $49.99 @ 16 oz
Directions:
Interior surfaces need to be clean and dry before applying Wolfgang Cockpit Trim Sealant.
Work on a cool surface in the shade.
Shake bottle well before and periodically during use.
Apply a small amount to a clean foam applicator and then work into the surface.
When working on smooth, hard surfaces use a separate clean, dry microfiber towel to wipe-off any excess product.
If less shine is desired on plastic, rubber, vinyl and leather surfaces, lightly buff with a clean, dry microfiber towel two minutes after application.
Warnings or Precautions:
Keep out of reach of Children
Harmful If Swallowed
Testing:
I first cleaned the seats of the 2 week old Optimum Protectant Plus using Meg’s APC @ 10:1 and then following it up with Ultima Interior Shampoo Gel. I usually use UIGP but wanted the OPP for some reason the last time.
I then ran a tape line down the half a seat and dash section.
I then applied WG CTS to the test sections.
Just for my own curiosity I also applied UIGP to the other half of the seat and dash to see if there was any difference.
Clean Seat / Dash:
50/50 Seat / Dash:
WG CTS vs. UIGP:
As you can see WG CTS leaves a little more glossy finish than the matte finish of UIGP. Personally I like the slightly glossier look for certain interiors and surfaces.
Pros:
1. Easy to Use
2. No Streaking
3. Nice Gloss that not over the top
Cons:
1. Price: It is slightly higher per ounce than UIGP
2. Chemical Scent
Questions:
1. Does it have the same durability as UIGP?
2. Can the Scent be changed?
Final Thought / Summary:
WG CTS is an easy to use interior sealant that is good for all your interior surfaces. Only time and future use will determine if the claim of dirt & dust repelling is true. WG CTS leaves a little more glossy finish than the matte finish of UIGP. Which on my seats I did like a little better. Sometimes UIGP’s matte look is almost a little white and hazy for me. If you are looking for a new interior trim sealant WG CTs might just be something to look into.
By TroyScherer
Product Details:
Directions: Yes
Color: Clear
Directions:
Testing:
Clean Seat / Dash:
50/50 Seat / Dash:
WG CTS vs. UIGP:
Pros:
1. Easy to Use
2. No Streaking
Cons:
2. Chemical Scent
Questions:
WolfgangCarCare
10-25-2013 07:20 PM
