Question on 87 911 Targa
Any suggestions on trouble shooting the cruise control on a 1987 911.
It engages but continues to accelerate until I use the lever to disengage or hit the brake. Don't know where to begin to try to diagnose.
thanks in advance.
thanks in advance.
I have never pulled apart the 911 cruise control before, but I know the actuator is like the 944, so I assume it has a cruise control brain as well. In the 944's the solder joints will go bad causing symptoms such as yours. Usually pulling it out and have a tv repair man or electronics guru resolder the board will fix the problems.
Got it. A little challenging to bend the tabs holding the pc board in the case but mission accomplished. The board looks very clean but will examine under a glass for cold spots or voids. Thanks again for your assistance.
