2001 Boxster Headlight Control Module location
I need help locating the headlight control module (relay) for a 2001 Boxster. I have no power (12 volts) coming into my fuse box for my headlights. AllData (useless) claims it's above the fuse box except there are no relays there, it blank. I checked above the radio and it's not there. The wiring dig. calls it a daytime running light control module. Any help would be appreciated .
I would guess you have a bad emergency brake switch or a bad microswitch where the handle latches or May be your convertible top controller has come loose? It's the "double sized" box up under the dash in the drivers footwell. Just try to wiggle it while you press it upwards...Same thing happen on my Fog Light.
I think it will work for him
