79 930 turbo loss of power problem
Old 01-05-2007 | 12:40 AM
930turbowoosh's Avatar
Default 79 930 turbo loss of power problem
I use to be able to get on it and spin the tires in 1st gear, after a long period of the car sitting there we finally got it running again. Go for a test drive and we are thinking its a lot slower, wont spin tires , or even in the rain! In 3rd gear the wastegate opens and the rpms jump to 4k quickly and then just stays like that, wastegate open but no more RPMS are building. Any ideas? It also smokes a little white smoke outta the drive side tail pipe . Could it be some sort of vacuum leak, timing issue, bad turbo, ect?
Old 01-05-2007 | 01:03 AM
Default RE: 79 930 turbo loss of power problem
Bad turbo, bad wastegate, bad spark plugs, cap, rotor would all be places to start. You can pull the intake boot on the turbo and check the condition of the impeller fins. How long was the car sitting, and did you do any work to it while it sat?
Old 01-05-2007 | 01:14 AM
no work was done while it sat. Ill check the compressor housing blades right now along for shaft play and oil leaking . Thanks!
Old 01-05-2007 | 01:26 AM
Pop your D cap off and check that and the rotor while you are at it.
Siy
02-09-2009 09:15 AM
bos33sox
01-14-2009 10:52 PM
MYT WYT
03-08-2007 11:18 AM
woodseller
01-02-2007 04:06 PM
mzyvcpc
01-17-2005 10:05 AM
