944 T - Getting hot in here!
My 1986 944 T is spewing hot air into the interior. Can't turn it off obviously-944 constant circulation- so it is a real pain. Air works for a while then gets heated up as well. Less hot air when car is not moving. Duh...
Anyone had this problem?
John
John
RE: 944 T - Getting hot in here!
Check the vacuum line from your firewall to the heater control valve. If that is on, then underneath the dash on the control unit is a clip that usually breaks and will lead to hot air all the time. It is about a $2 clip.
