996 Air Condition Please Help Hot Outside
RE: 996 Air Condition Please Help Hot Outside
Run the engine, with the compressor engaged, after a couple of minutes, touch the bigger rubber hose (returning) and than the smaller one (high pressure), you have to feel a bigdifference in temperature, if not, 1. low freon, 2. expansion valve is closed (prob. water in system) 3. compressor failing. 4. Your climate control does not work (that would be the most expensive repair). Try a good airconditioning service, to have your system checked out, before concidering changing the climate control. Good luck.
germania
05-19-2009 01:33 PM
