996 turbo -01 misfires after oilpump change
Old 02-17-2011 | 10:27 AM
turbodavid's Avatar
Default 996 turbo -01 misfires after oilpump change
Hello.
I have the car spinning around at third gear at track and the car turned around and the engine started too go on the wrong way. the result was an oil pump failure.
now after i have changed oilpump and severeal other things like camshafts lifter at the inlet side (all)
6 spark plugs org from porsche.
6 coilpacks.
vario cam inlet sprocket.
the car is misfiring at 2900-3300 rpm when you have even a little boost.
but when i go past this rpm and floor it it doesnt misfire but the car have no power at all..
when reving in neutral it misfires too.
when i read with durametric i can see the misfiring in order. it always starts at 1 cyl then 2 then 3. ..
the variocam plus is working.
below 2800 rpm the car goes normal besides some puffs at idle.
i now donīt have anymore ideas except maybe the dme. but itīs expensive enough already.
greatfull for fast responce...
DaveW
03-07-2009 07:15 PM
Scott449
10-22-2008 11:47 AM
motoxr828
07-17-2007 06:47 PM
CanadianAERO
03-04-2006 12:02 AM
996C4
10-22-2004 01:58 AM
