996 turbo hydraulic spoiler 3rd light removal
Old 11-06-2007 | 01:23 PM
doug's Avatar
Default 996 turbo hydraulic spoiler 3rd light removal
The 3rd tail light located center on the hydraulic spoiler has what looks like a small access panel with a notch. Sliding a small screw driver in the notch to gently try to pry it open isn't doing the trick.
[IMG]local://upfiles/5192/AB1CC2E61DA442F0BB5FB782583960DC.jpg[/IMG]
[IMG]local://upfiles/5192/8CBE5E84F73B411D9DC22960A5BDDAA8.jpg[/IMG]
Old 11-06-2007 | 05:29 PM
doug's Avatar
Default RE: 996 turbo hydraulic spoiler 3rd light removal
the side piece is to be pryed open which allows the light to be removed. it's stuck so it may crack or break on removal. the dealer has the replacement for 129.00
Old 11-06-2007 | 05:39 PM
Should just pop off with a small screw driver, then there is a plastic screw that you turn 90 degrees underneath and the light pulls out.
Old 11-07-2007 | 01:27 PM
doug's Avatar
thanks for the help. in the meantime I obtained a manual with all of the light removal steps in it
Dr944S2
06-14-2012 04:59 PM
Rob Shapland-Hill
04-22-2012 11:03 AM
carfan1
12-27-2010 06:10 PM
detailsplus
01-22-2009 03:12 PM
pmettes
02-11-2007 05:17 PM
