devide split pst file
Old 05-12-2014 | 03:23 AM
kennthwatson's Avatar
Default devide split pst file
PST file into smaller part but failed to decide the right way for you? Here in, you should try our advanced Split PST File Tool. Apart from splitting large sized PST file, this software has various other features. When MS Outlook slows down its process due to large size of PST file, the Split PST File software performs better and breaks large size PST files by date, year, size and folder.
This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows.
n case, you are using either Outlook 2002 or the earlier versions, if the storage capacity reached or exceeds 2 GB, it becomes the requirement to break PST file for better performance.FOR FREE recover of data LOG.in here: http://www.undeletepcfiles.com/split-pst-file.html
use free demo version.
Old 02-03-2015 | 01:05 AM
RaymondStewart's Avatar
The are an other affordable and more advanced option to manage large sized PST file is to split large PST file into small sizes. You can use Split pst file to split large file. You can get detail from here :- http://www.recoverfilesdata.com/split-pst-file-tool.html
Old 05-12-2015 | 02:56 AM
johnbutlor's Avatar
Default PST Split Tool
There are so many PST Split Software but Kernel for PST Split Tool is best, simple, secure and awards winning Software. It split large PST file without data loosing. It support multiple splitting option. User can split every Outlook item like email, contacts, calendars, journal etc. Read more and download free trial version from - http://www.pstsplitter.net
Old 07-20-2015 | 05:27 AM
kennycureton's Avatar
Banned
Software is designed to split large pst file into small size pst files on the basis of sender's e-mail IDs and date. Interactive user interface makes it easy to split pst without any prior experience.
Try:- Split PST File Tool Divide / Break Large Outlook PST into Small PST Files - PST Splitter
Old 09-10-2015 | 04:45 AM
Rawatsonika4u's Avatar
Banned
SysInfoTools Advanced PST Split software which is an easy & effective way to split large PST file into small pieces. Software provides 4 effective options to split multiple PST files like that like:
a) Split PST by Size
b) Split PST by Date
c) Split PST by Sender email id
d) Create single PST file for selected folder
e) Create separate PST file for every selected folder
Visit here for more details of this advance tool: PST Splitter Tool
Old 10-05-2016 | 05:52 AM
kid_kad's Avatar
Thumbs up How to split PST files?
There are three different tricks you can perform manually for splitting PST files. Outlook client provides you few built-in features and function which you can use to import mailbox folders from one PST files to multiple new PST files. You can use Archive, Import & Export and Move to Folders features in Outlook. For more information, you can read this blog post:
Easy Way to Split PST File into Multiple Smaller Parts | N. Sem's Blog
In this blog post, you'll get complete information about how to split PST file manually. I hope the shared information would be helpful here.
If the manual tricks fail or don't work for you, then only you should try professional PST Split software. It will split PST file into multiple parts without causing any changes or damage to original mailbox data. It will provide you different split options. You must download its free demo version first.
Thanks and best regards.
Old 08-14-2017 | 01:38 AM
Phillcalls's Avatar
Download Outlook Split PST Tool to break large sized PST with all saved emails, messages, contacts, calendars, appointments and other data items. Split PST Software allows MS Outlook 2016, 2013, 2010, 2007, 2003, 2002 etc. user break their required large sized Outlook PST files in small PST files by Date, Size and Email ID.
See more here: Break Outlook PST File
Old 11-20-2017 | 05:46 AM
amazsilong's Avatar
Microsoft Outlook has provided three inbuilt functions by which user can make their PST file smaller i.e.
1. Move PST file items by using Archive feature of Outlook
2. Import & Export feature of Outlook to move PST file items
3. Move PST file items by using Move to Folder feature.
By taking help of above three inbuilt features user can make their PST file small. However, In my case these
features were not effective. I took help of <!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Download PST Splitter to Split Oversized Outlook PST Files ? Divide PST in Small PST PST Splitter.
Old 11-13-2019 | 02:35 AM
jennifershine15's Avatar
Default Divide PST files
If anyone wants to split the large PST files then I would suggest trying to use the KDETools PST Splitter. It split the large PST files into small parts by date, size, year and folder according to need them. It split the large PST files in ANSI and UNICODE. This tool support without installing MS-Outlook. It supports all the Windows Version and Outlook Version.
More Details: Split PST Tool to Divide/Split Large Outlook PST File into Smaller Parts
  #10
Old 12-03-2022 | 05:40 AM
FredB's Avatar
You are surely looking for a quick solution on how to split large PST files to make the work easier we have. That it breaks Outlook PST files according to size, year,
and folder immediately. You use this utility to split PST files in Outlook 2019, 2016, 2013, and 2010 without data loss and security issues. Split PST is a user-
friendly application that enables users to split PST files freely. PST Split is a secure tool. Which splits a PST file with top accuracy. Splits all email properties,
contact details, and folders without losing a single piece of information. With ToolsBaer Outlook PST Split Tool file split software, users can split multiple large
PST files in a single process.
