Gas tank won't fill
Old 12-10-2008 | 01:53 PM
rich21ard's Avatar
Default Gas tank won't fill
HELP!!!!
I have a 2001 carrera and i can not get the tank to fill...... I try to fill it and the gas just spews out of the filler neck. If i fill it at a trickle I can get 1/4 tank in there but it takes 15 minutes to do that....... Any ideas?????? Solutions????? maybe a check valve? maybe a vent tube blocked?
thanks
Old 12-10-2008 | 04:27 PM
Default RE: Gas tank won't fill
Yup, sounds like one of the check valves may be bad. Also there is a TSB, where one of the lines on the fuel sender can get in the way and block off the fill port on the inside of the tank. Basically it involves removing the sender unit, and securing the lines to the unit better.
dave1986944
06-05-2011 04:13 PM
Hammer Brothers
09-15-2008 11:00 PM
omnia2
03-24-2008 10:50 AM
eeluddy
12-02-2007 06:38 PM
kenbee
12-01-2006 12:40 AM
