Oil leak at valve cover drivers side
Old 01-19-2009 | 01:06 AM
mkolseth's Avatar
Default Oil leak at valve cover drivers side
I own a 1978 911 sc with 47000 and the car sat for 16 years or so without being driven. The car was not stored properly before parking but was kept in doors all those years and is in great shape. I had a local/repitable repair shop do a number of things to get this vehicle road ready and I'm happy with all the things they performed as I now put on aprox: 800 miles of great driving. However is there something difficult about sealing the valve covers properly on this vehicle. The valves were adjusted and new seals were replaced. I returned a second time due to oil leaking to the ground after parking a day or two. The tech. found a bolt slightly loose and retightened but still have same problem at left rear. Appreciate any good advice. Thanks Mike.
Old 01-19-2009 | 12:42 PM
Default RE: Oil leak at valve cover drivers side
The 911 covers are prone to warping. You can replace the paper gasket, but if the cover is warped, then it will just leak again. You are stuck with buying new replacement covers, or go with aftermarket billet aluminum covers with the updated 964 rubber gasket from Imagine Auto.
Kingsnawwww997
06-21-2009 01:16 PM
cshkc
08-30-2007 12:15 PM
jimmys66
06-02-2007 12:24 AM
jac
04-06-2005 12:36 AM
BAShibby21
03-18-2005 01:34 AM
