Oil Level Sending Unit question
Old 02-26-2011 | 10:53 PM
o1marc's Avatar
Default Oil Level Sending Unit question
I am powder coating the oil tank off a 74 911 and had a question on the level indicator. I was heating it up and noticed the plastic ring around the spade fitting on the cap started to melt so I pulled the mechanism out of the tank. I noticed how it works by the arm resting against a flat piece of metal inside when it is full and on another piece when it gets low. The second spade bolts to one of the 5 studs on the tank, this one being a ground I assume that connects the crcuit when in the full or empty position. I assume the plastic is there only to keep the 2 sspades from connecting outside the tank and probably wont harm anything if its not there as long as care is taken to make sure the 2 spade connectors dont touch. Can someone back me up on this. I would prefer not to paint the cap and coat it to match the tank. I dont see anything else the heat can harm.
ehroof
11-21-2008 10:59 AM
asifallasleep
09-07-2007 10:48 AM
drsharps
08-16-2006 11:14 PM
BIBBER
06-13-2006 11:38 PM
pwb510
10-16-2004 05:33 PM
