Short Shift kit on 02 911--worth it?
Old 09-18-2005 | 03:27 AM
Coughran's Avatar
Default Short Shift kit on 02 911--worth it?
I have an 02 911 and am considering a short shift kit. But none of the porsche garages around Seattle I've talked to have installed one on an 02. I'm wondering if anyone with an o2 has installed one--which one?--and did it really make a difference?
Thanks.
Old 09-18-2005 | 03:03 PM
Default RE: Short Shift kit on 02 911--worth it?
Go with a B&M short throw shifter. A short throw is the FIRST upgrade that should be done to any boxster or 996. The reduce in throw is incredible, and after doing it, you will not ever want to drive a 986/996 without one, in fact driving a stock shifter after you have driven a short throw is absolutely hideous. It really makes driving the car enjoyable. The install is pretty easy, i can probably do a writeup from memory on the install if you send me your email, as i have installed a ton of them. First time, takes 1.5-2 hours, hardest part is you have to break out the old bushings for the old shift handle with a chisel, one of those things where a little force is better.
Old 09-21-2005 | 01:06 AM
944turboS's Avatar
short shift kits are nice, and there is a difference in terms of shift times (but unless ur racing it doesnt really make a difference) and personaly i agree with Coughran taht it should be the first upgrade u should consider ( plus its cheap and doesnt take to long to instal)
Old 09-21-2005 | 01:20 AM
ORIGINAL: 944turboS
In the 996/986 it makes a big difference in driveability. Seriously a stock 996 or boxster has a long shifting throw similar to my truck.
Old 09-22-2005 | 11:30 PM
I just installed another B&M yesterday, got it down to 30 minutes, but i was hauling a$$ I realized that in the bottom underneath a sheet of cardboard are instructions on installing the kits from B&M with pictures. Should walk anyone through it.
Old 09-25-2005 | 04:53 AM
Coughran's Avatar
Thanks Doc. I wish you were in Seattle, I would drive it on down for you to do it.
Sounds like something I must do.
ET1KTRD
06-27-2011 05:31 PM
carsnob
09-27-2008 10:14 PM
911Joe
04-20-2008 07:19 AM
MikeV
01-07-2008 08:45 AM
roncordell
12-31-2006 05:00 AM
