Tire pressure
Old 04-14-2008 | 12:33 PM
tinchao's Avatar
Default Tire pressure
Hello, the driver side door has a label saying front tire pressure30 psi, rear tire preasure37 psi, however, the fine print on the side wall of the tires also has a tire pressure, the listed Max pressure on the the side wall of the tire is always much higher than the label on the car. Which one I suppose to follow? Some say I can go a bit higher than the label. Please advice and explain a litte. Thanks.
Old 04-14-2008 | 04:33 PM
Hot911TT's Avatar
Default RE: Tire pressure
I use the label
Old 04-14-2008 | 07:01 PM
Lee Willis's Avatar
The max pressure listed on the tire is a warning not to exceed that, not a recommended pressure. I run the factory recommended pressures all around on my Porsche.
k2we
10-28-2009 05:56 PM
c4s911
09-27-2008 10:26 AM
mcarter
12-20-2006 06:03 PM
alfaGTV
03-10-2006 12:30 AM
coxon
10-22-2004 12:02 PM
