What Everybody Ought to Know About Lotus NSF to PST Conversion?
Old 02-24-2015 | 01:18 AM
JamesFajardo's Avatar
Default What Everybody Ought to Know About Lotus NSF to PST Conversion?
Often, professionals and home users working with Lotus Notes email client need to migrate their emails to MS Outlook platform. As, Lotus Notes create .NSF file whereas MS Outlook create .PST file and both of them have their unique features and they are not compatible to each other. In many cases, MS Outlook is better than Lotus Notes. Advanced features of MS Outlook attract Lotus Notes users for NSF to PST converter tool.
Converts the Lotus Notes file (*.nsf) into an Outlook (*.pst) file . You can directly import the converted PST files into Microsoft Outlook and access all your emails and other components, including Attachments, Contacts, Calendar Entries, and Journals etc.
Provides option to save the converted mail items folder as MSG, PST or EML files. The software either saves the converted mail items in a new PST file or appends them to an existing one.The Software is capable to automatically locate your NSF file, or if you want to select any other file, you can select any local or server mail file for export.
Once this Software creates the PST folder, you may export directly to Outlook or choose to export to a sub folder. Quick Recovery's unique Guided File Excavation Technology (GFETCh) helps in locating email files and folders.his is the best NSF to PST Conversion Software. The Software supports to convert Mails, Address Books & Calendar of NSF files.NSF to PST Converter keeps the format intact even after migration. It takes care of TEXT, HTML or RTF formats when saving.
User can choose from a specific date range and decide to include/exclude “All documents” folder from Lotus Notes to Outlook. They can also save these files in .MSG and .EML file formats, in addition to the above mentioned file format. The software supports UNICODE conversion as well and comes with free trial edition.
So See More Info About This Software: http://www.filesrepairtool.com/nsf-to-pst-conversion.html
Old 03-20-2015 | 07:19 AM
JoseSpence's Avatar
NSF to PST Converter Tool is a professional and result oriented NSF contacts conversion tool for Lotus Notes users who want to export contacts to MS Outlook. Users can review converted NSF contacts before exporting.You can download this tool from here :- NSF to PST Converter – An Expedient Tool for Lotus Notes to Outlook Migration
Old 05-20-2015 | 06:58 AM
abelmartin002's Avatar
You can download this tool to repair and convert all EDB file to PST file format. This tool easily converts all EDB file to PST file format without any loss data. This tool supports all EDB and PST versions. You can check this tool along with a free trial from here: http://www.recoverydatatools.com/nsf-to-pst-converter.html also read this post: Lotus Notes to MS Outlook Conversion Software
Old 05-27-2015 | 05:04 AM
RobertGrant's Avatar
Use Lotus Notes to Outlook software for converting all items of Lotus Notes (NSF) files to Outlook (PST) files format including emails, drafts, journals, permanently deleted emails, contacts, attachments, notes, sent emails, appointments, etc. For more information visit to :- http://www.mannatsoftware.com/kernel-lotus-notes-to-outlook.html
Old 12-23-2015 | 05:26 AM
Arban Delacruz's Avatar
Default NSF to PST Converter software
RecoveryFix for Lotus Notes to Outlook converter tool is the best way for those users who are planning to convert NSF files to Outlook PST file format. The tool has a lot of helpful advanced option that provides quick and easy method to perform the conversion. Read more here: NSF to PST Converter Software to Convert Notes NSF Files to Outlook PST Files
Old 05-04-2016 | 11:22 PM
jsen's Avatar
Default NSF Converter Software
Using NSF to PST conversion program all consumers can repair and recover NSF file to PST, EML and MSG format. It will split converted PST file in MB size without any problem. Solution of NSF converter easily Export NSF contacts as CSV file with whole versions of NSF file and outlook.
Read More
http://www.nsftopstconversion.esofttools.com/
Old 07-31-2017 | 08:59 AM
lucasdawson1984's Avatar
Here is a blog the explain all you need to know about NSF to PST conversion:
How To Convert NSF File Into PST Format
Old 12-30-2017 | 04:41 AM
kanariyajoseph's Avatar
Old 05-16-2018 | 06:02 AM
sentluis31's Avatar
Use latest NSF to PST conversion tool for swift migration of NSF accounts to PST format. It export email, attachments and all other data of the NSF to PST file format. For more information about NSF to PST conversion tool kindly visit here http://www.recoverydatatools.com/nsf-to-pst-converter.html
  #10
Old 05-18-2018 | 07:06 AM
freyasmith's Avatar
For conversion of lotus notes to outlook file there you can download the wonderful NSF to PST Converter software which smoothly recover data for NSF file and convert NSF to PST, EML, MSG, HTML, EMLX, CSV and ICS format. With the help of NSF to PST Outlook Converter software you can also convert selective folders from NSF file and restore all NSF file data into PST Outlook file without losing any information from NSF file. There requirement of installing lotus notes application to perform NSF file to PST File conversion and no outlook installation for conversion.
Read more info:- SysInspire NSF to PST Converter Software to Free Convert NSF to PST
ramonvega
05-13-2020 03:23 AM
abelmartin002
02-12-2020 02:25 AM
kennthwatson
09-24-2018 01:15 AM
NicholasGonzalez
07-21-2018 03:02 AM
