1980 SC starting problem
Old 11-06-2007 | 05:06 PM
sludge1300's Avatar
Default 1980 SC starting problem
Recently I've been having an intermittant starting problem. When I turn the key, the fuel pump activates, but it doesn't turn over. This happens only every now and then, such as after I've driven a bit. If I leave it sitting and it started while sitting, it will continue to start...sort of like there's a short or a loose connection. I checked the battery and starter solenoid connections, both are good. I was thinking maybe it could be the solenoid ground, where does it ground to? Any other ideas or suggestions? Thanks
nuts4porsche
03-31-2011 12:31 PM
swooney
06-30-2008 12:44 PM
kevfran
07-30-2005 04:53 PM
dwendt
07-20-2005 03:27 AM
cycotic_penguin
04-08-2005 08:16 AM
