2002 Oil consumption
Old 05-08-2008 | 09:50 PM
cmilam's Avatar
Default RE: 2002 Oil consumption
That doesn't make sense.
  #12
Old 05-09-2008 | 04:49 AM
Big Bob's Avatar
If you are certain the consumption has deteriorated to 300, then take it back and discuss with the dealer. 300 is a little high. Even I who does not mind oil consumption, for reasons I've documented on other threads, that needs checking. Regards Big Bob
  #13
Old 05-09-2008 | 05:37 PM
Hot911TT's Avatar
but where is that oil going? It's not smoking and it doesn't leak
  #14
Old 05-10-2008 | 03:33 AM
Big Bob's Avatar
Thats why I think it is very important to be sure its doing 300. Another thought is to get someone to follow the car when its being driven to see if there is a continual light haze, not detectable through the rear view mirror, but might point to a regular loss through the combustion chambers.
Regardds Big Bob
  #15
Old 05-10-2008 | 09:00 AM
cmilam's Avatar
I think you'd also smell it.
  #16
Old 05-10-2008 | 09:59 AM
Big Bob's Avatar
Possibly, but when you can smell it, its usually bad and you can see it through the rear view mirror. But if this is a higher RPM issue you will need some one to watch it under load.
Running it at high speed in idle may not show it up.
Anyway its an interesting mystery that I hope we get the answer to.
Regards Big Bob
  #17
Old 05-11-2008 | 09:48 PM
Hot911TT's Avatar
You should be able to see it on the down shift.
  #18
Old 05-11-2008 | 10:42 PM
cmilam's Avatar
With that much consumption you should see more than a light cloud
944speedy
08-27-2009 11:41 PM
Teetee
10-28-2008 02:51 AM
bion
07-04-2008 03:17 AM
app1nag
10-18-2007 06:53 PM
dave1986944
07-09-2007 10:41 PM
