73 911T oil leakage
Old 11-29-2004 | 06:43 PM
coxon's Avatar
Default 73 911T oil leakage
best I can tell its leaking fom the case split, after sitting a couple weeks. Does this sound normal for an engine thats never been apart? Is my only solution to completely disassemble engine I replace case gaskets?
Old 01-05-2005 | 01:59 AM
Me944's Avatar
Default RE: 73 911T oil leakage
Double check the oil return tubes. They have a tendency to leak, and are very easily replaced. It is possible that the oil is leaking from the return tubes, and running down to the case split, which is the lowest point under the motor, and giving the apearence of leaking from the case split itself.
Jacob25119
06-03-2009 04:50 PM
Barbied0ll
01-06-2009 12:54 PM
mechcyber
09-05-2007 05:08 PM
jeff_rx7
03-25-2007 11:44 PM
coxon
10-22-2004 12:02 PM
