73 911T oil pressure
Old 10-04-2004 | 05:47 PM
coxon's Avatar
Default 73 911T oil pressure
what is the normal oil pressure for this engine? Car runs fine & has only 59 km from new but reads way less then what most engines run at in the 40-60 psi range. Should I expect the same level?
Old 10-22-2004 | 12:02 PM
evanskevo's Avatar
Default RE: 73 911T oil pressure
oil pressure when idling and hot will be negligible
oil pressure when running down the road should be ~80 psi (give or take)
kinderrich
12-29-2005 12:35 AM
mdbloom
07-22-2005 05:25 PM
Nordschleife
03-25-2005 02:19 AM
banjogary
02-14-2005 04:18 PM
coxon
01-05-2005 01:59 AM
