Battery Charger
Old 04-08-2006 | 06:50 PM
Billco's Avatar
Default Battery Charger
Unfortunately, I don't drive my Carrera enough to keep the battery fully charged. Have any of you had experience with the charger that plugs into the cigarette lighter? Are there other, non-Porsche products that work as well or better? Thanks.
Old 04-08-2006 | 10:48 PM
Default RE: Battery Charger
I would get an actual battery tender that hooks up to your battery. It utilizes a quick disconnect plug, so you can just unplug it and go, so it is nice as far as that goes. Even with a battery tender, you still need to drive the car a couple times a month to keep the charging system healthy.
Old 04-10-2006 | 03:11 AM
Billco's Avatar
Does this suggest that the ones that work through the cigarette lighter are not as good? If they are, it would seem to be easier than installing something on the battery. What do you think?
Old 04-10-2006 | 10:30 PM
Lee Willis's Avatar
Yeah, the doctor is right, the ones that plug into the power outlet will not work as well as a good battery tricle charger with a float feature. I have one I rigged up for my vette since it sits for long periods (2--3 weeks) without running.
carid
12-04-2014 04:00 AM
MBEEZ911
01-08-2009 05:53 PM
richc
10-23-2008 11:48 AM
OnesickCarreraGT
04-25-2008 07:50 PM
mattyg50
10-30-2007 12:08 PM
