Clutch problem lever will not disengage
Old 12-28-2004 | 03:33 AM
cu911's Avatar
Default Clutch problem lever will not disengage
I have an emaculate 84 911 SC Cab. I have a problem with The clutch and I don't want to pull down the engine if I don't need to. The problem is the clutch is in the engaged position and the lever is in the release position. I believe the problem is a broken lever or thrust bearing and would like some advice on other possibilities before I pull down the engine.
Please give me your thoughts on what you believe the problem could be.
Thanks Rog.
mcb1549209
10-15-2009 02:08 PM
Mr.74911
02-18-2009 01:21 AM
etwd
10-28-2008 12:27 PM
first timer
07-25-2007 06:20 PM
Bound.By.Ink
01-12-2007 02:48 AM
