Crunchin/Clunking noise to front
Hi All,
I have just purchased a 1984 911 and have noticed that there is a crunchin/clunking noice from the front pass side when turning the steering. It kinda sounds like a bearing but does not happen unless the steering is turned.
Any ideas.
Cheers
Any ideas.
Cheers
RE: Crunchin/Clunking noise to front
Typically bearings that are going bad will ONLY make noise when you are turning the wheel. With the wheel in the air, grab at the 12 oclock position, and the 6 oclock position, and give it a wiggle. If the tires has play, then your bearings need attention.
johnny hatchback
12-04-2007 01:14 PM
