How to do an oil change on a 2002 911 Turbo
RE: How to do an oil change on a 2002 911 Turbo
remove the 15mm drain plug from the case. Remove the 19mm drain plug from the reservoir tank. Remove the 8mm allen drain plug from each turbo drip tank. Drain all oil out. Replace all plugs, making sure you use new aluminum crush seals. 20x26, 22x27, and 18x22 (2). Remove filter from canister housing in the engine bay, replace filter and oring, and reinstall the canister. Add 8.5 quarts of oil and you are good to go.
