Oil change
Old 11-10-2007 | 09:49 AM
red_smeg's Avatar
Default Oil change
Hi,
I want to do my own oil changes on the 2005 997. does anyone have a manual for this model I can't find one in the stores and don't want to pay megabucks either.
Old 11-10-2007 | 11:28 PM
Default RE: Oil change
It is just a 8mm allen drain plug on the bottom of the pan, along with the filter next to the pan (canister with paper filter insert). Replace the o ring on the canister when you put on the new filter. 8.5 quarts of 0w-40 mobil 1 and you are good to go.
If you service now indicator is on though, you will have to take it to the dealer to have it reset with the PIWIS
Old 11-10-2007 | 11:29 PM
You will also need a new 18x22 aluminum crush seal for the drain plug.
Old 11-12-2007 | 01:51 PM
htownbdr's Avatar
Where is a good place to order the filter and crush seal?
Old 11-20-2007 | 11:37 PM
snappy's Avatar
Go to your local porsche dealer to buy the filter and washers. Not sure on your year but you might need the oil canister remover tool. Should be less than 1 hour work. Good luck..
kingds
08-22-2005 02:15 PM
911C2
07-16-2005 12:32 AM
Dr997
07-06-2005 12:58 AM
996C4
10-22-2004 01:58 AM
GreatAlexandros
06-17-2004 07:11 PM
