Starting Trouble
Old 08-12-2007 | 04:09 PM
Porsche Guy's Avatar
Default Starting Trouble
I have a 1969 Porsche 911 and it refuses to start for me. I have checked for spark but have none. I have replaced coil after coil and still no spark. The carbs have been rebuilt also. We have done the test to check for spark at the coil by holding coil wire 1/2 inch away from good ground which sometimes gives us a spark. But still the motor will not run. Any suggestions ???????????????
Old 08-13-2007 | 12:47 PM
wdonovan's Avatar
Default RE: Starting Trouble
No spark or sometimes jumps a 1/2" spark? Which one? A half inch is pushing it. Will it jump a 1/4"? Have you put a timing light on it? Is the timing right? Do you smell fuel when it won't start?
Old 08-14-2007 | 04:26 PM
The timing is correct and I have fuel. Thank you for your reply, we have found out that the coil wire was to blame. Replaced with used wire, new ones cost wayyyyyyyyyy to much, and it fired right up. Thanks for your help.
danielmllr
11-18-2011 06:33 PM
rring4261
08-31-2006 05:22 PM
nankipoo
06-17-2006 05:24 AM
cancerofhumanity
02-23-2005 09:12 PM
porsvett
04-22-2004 08:12 PM
