928 Timing Belt Replacement
Old 05-13-2007 | 08:56 PM
Brian Felts's Avatar
Default 928 Timing Belt Replacement
Hey all new here........I have the awesome oppertunity to trade for a 1984 928with less than 94000 miles on it. My questions is how big of a do it yourself hassle is the timing belt change. I am a decent mechanic on BMW's and Mercedes but they all use chains. The car I am looking at has no service records but you can tell it has not been abused.
Thanks for any tips or info
Brian Felts
www.geocities.com/southernohioauto
Old 05-13-2007 | 09:17 PM
Default RE: 928 Timing Belt Replacement
Well, its not exactly a fun job, but there are some decent writeups that will walk you through most of it.
Old 05-14-2007 | 04:39 AM
Ok Cool do we need that "special $500" tool to do the belt in a 928?
Do we have one of the interference engines?
I appreciate your time, its been a dream of mine to own a 928 and a fellow has offered to make me a trade for a Camaro I just restored and I would like to take him up on it but I have a 16 mo old and I need something I can depend on as a second fun car.
Brian Felts
Old 05-14-2007 | 08:52 AM
I don't know that I would call a 928 exactly reliable. They aren't bad, but you are talking about a 23 year old car. Those don't fall in the reliable category as I look at it. Stuff wears out after 20 years, and you will always be fixing something, especially on a 928. If your engine is the old 16V, then it is not an interference engine. When they changed to the new engine with the 32V design, then it became an interference engine.
I have the 9201 tool, but I don't use it anymore. It is good to have it if you have never done a belt before. I use the 90 degree twist method, and I can get very close to what the tool says at any given time. IMHO the tool is over engineering by Porsche. It can give a different reading without changing the belt tension, so I don't put a lot of weight into it.
obboardcamera
01-25-2007 01:12 AM
88_944
11-22-2006 10:51 PM
drummer_toxik
06-30-2006 01:43 AM
luckybuster
03-27-2006 01:04 PM
ichosun1i
09-01-2005 01:01 AM
