1984 944 shifting problem
Old 06-14-2007 | 12:08 PM
wrinehart's Avatar
Default 1984 944 shifting problem
I have a 1984 944 that will not engage when I put it into gear .
I do not believe it is the clutch because if I attempt to turn the car over in gear it does not move it grinds.
there is also a noise from the drive shaft which may indicate that ther drive shaft may have disconnected.
I can start the car out of gear but hear a noise near the drive shaft like there is something loose .
Any ideas
Old 06-14-2007 | 03:38 PM
dwhita6605's Avatar
Default RE: 1984 944 shifting problem
does that grinding noise go away when you push the clutch in? as well as when you start it. if not. then the problem might be up front as well as the transaxle in the rear. get alittle dirty and look under the car at the drive shafts as well as the torque tube play with the both of them make sure they are secure, not snapped or stripped in any way.
thats about as much as i know...
Goodluck.
Dave
Old 06-14-2007 | 03:41 PM
wrinehart's Avatar
Yes you are correct the grinding noise goes away when I push the clutch in .
Old 06-15-2007 | 08:24 AM
sounds like a shattered R&P. Did you do any hard launches prior the the failure?
Also look back and make sure your CV axles are still connected to the transmission.
Old 06-15-2007 | 02:26 PM
wrinehart's Avatar
the car made a whining noise in the front of the car near the gear box prior to the problem happening .
Old 06-15-2007 | 03:30 PM
Not sure how that is possible, as the gear box is in the rear of the car.
Old 06-15-2007 | 03:49 PM
wrinehart's Avatar
sorry for my lack of terminology here
I do appreciate your imput
the noise was from right below the gear shift
piratescabin
08-31-2012 03:55 AM
MajnoLo
02-13-2010 03:44 PM
piratescabin
02-09-2008 01:06 PM
Mr.Puff
08-17-2007 05:12 PM
944diehard
08-15-2007 02:54 PM
