1987 944 S 2.5 16 Valve N/A will not start
Old 04-30-2007 | 01:08 AM
kinderrich's Avatar
Default RE: 1987 944 S 2.5 16 Valve N/A will not start
item 31
[IMG]local://upfiles/1568/5A9AFA51BA054DA7AD3EECA7ADFF1760.jpg[/IMG]
  #32
Old 04-30-2007 | 01:13 AM
kinderrich's Avatar
wiring diagram
[IMG]local://upfiles/1568/8BE66340DF64465086B82E1EC00E97F5.jpg[/IMG]
  #33
Old 04-30-2007 | 01:27 AM
Anthon33's Avatar
Jes' thanks dude if you wernt so far away I'd buy ya a beer!
  #34
Old 05-01-2007 | 09:32 AM
Anthon33's Avatar
I found the spec's for the Ballast resistors which is 6ohms. I got the same result when I tested mine so its ok.
I also have power to the Ballast and have continuity betweem the ballast plug and the injectors, so I am ruling this out as a problem.
  #35
Old 05-01-2007 | 02:50 PM
It is a speed sensor on the bellhousing, not a reference sensor. The hall sensor takes place of the reference sensor on the S
  #36
Old 05-01-2007 | 02:54 PM
Did you replace the DME with an S dme or an 8v dme?
  #37
Old 05-01-2007 | 07:03 PM
Anthon33's Avatar
I replaced with the correct DME for the 16Valve with matching part no. for this spec. according to the Porsche 944 S spec. & parts manual.
As you probably know there are only two part numbers that match the 'S' which are: 944.618.124.00 & 944.618.124.01. I have both.
  #38
Old 05-03-2007 | 11:33 PM
kinderrich's Avatar
Well since nothing has seemed to work, Have you tried bypassing the alarm. Checkout http://www.clarks-garage.com/ ELECT-23, Alarm System - Bypassing. That may be the Problem.
  #39
Old 05-04-2007 | 12:51 AM
Anthon33's Avatar
I would do only there is no alarm fitted, just a bridging connector where the alarm module would be on the loomb.
  #40
Old 05-04-2007 | 08:14 PM
kinderrich's Avatar
did you verify the bridge is shorting the correct pins together, also does your wiring harness have a resistor in place where the 02 sensor would be?
