85 944 tachometer problem
Old 07-11-2004 | 01:38 PM
kit1111's Avatar
Default 85 944 tachometer problem
85 944---My tachometer is reading very low rpm -it is starting at idle at 200 rpm and at what should be 5000 it reads 1000rpm. Problem -1st time since Ive owned it. Checked connection at the coil and I dont kow where the ground connection is?? Also could it be a fuse involved causing a weak connection?? If so which one??? Checked the manuals I have and no help.
Thank you in advance for your advise.
figurenine
05-26-2009 08:59 PM
Dans951
02-06-2007 10:42 AM
ls3mach
07-23-2006 04:22 PM
gyver_101
05-16-2006 12:47 AM
jaggraveyardcom
01-03-2006 08:48 PM
