86' 944 runs hot
86' 944 runs hot
Hi guys,
I own a 1986 944 na, i had the water pump, all the belts changed and the thermostat, head shaved and new gaskets, new valves and guides. Runs good but run very warm. I flushed the system yesterday and put 2 gallons of new antifreeze in it. I will run in the middle on the highway but on the streets, it will run on the third white line up to the bottom of the red line. If i give it some gas the temp will lower somewhat. I made sure there was no air using the bleeder. Anything i should be looking for?
RE: 86' 944 runs hot
how much air should be in the system, i bled it when it was hot and the engine not running then when running. Seems to be air in the system still. Whats the best way to bleed the system? Still runs on the line before the red, sometimes it will run in the middle of the gauge when on the highway. Fans are running when its getting warm. Any suggestions?
#10
RE: 86 944 runs hot
Hi,
I bled it again, still ran hot. I "cleaned" the radiator on the outside, figured it couldnt hurt to rinse with some water, just in case it was dirty.The temps seem to be slowly getting worse, not its running between the 3rd line and the red line on the highway and the funny part is that its much cooler out, temps outside in the mid 50's. Any more suggestions, I am getting concerned since its my wifes daily driver.
Thanks
Eddie
Thanks
Eddie
