'86 Hot start problem
Old 11-12-2008 | 05:53 AM
Anubis's Avatar
Default '86 Hot start problem
After my car has been running and I've parked it for in excess of 30 mins, it refuses to start. Cranks fine, fuel pump sounds active, but I'm getting no spark. If I wait for a little bit, it turns on without any problems. if I push start it, it comes right to life as well. New spark plugs and cables, but the problem still occurs. Checked various wires to the battery and starter, everything seems clean and making a solid connection. I'm not a mechanic nor a porsche expert, so I don't know everything to check that fits the symptoms... Ideas?
Old 11-14-2008 | 09:20 AM
Fast951's Avatar
Default RE: '86 Hot start problem
If you are able to push start the car then you are getting spark (power to the ignition) so I tend to think it is starter motor related. Could be a bad starter or something in the starter circuitry causing high resistance when the engine is at operating temp. I'd remove the starter and have it bench tested by a reputable rebuilding shop and then go from there.
Old 11-14-2008 | 07:03 PM
Speed and reference sensors are bad, or the harness to the sensors from the DME
Old 11-14-2008 | 11:47 PM
Fast951's Avatar
ORIGINAL: PorscheDoc
You sound so sure of yourself;I'm impressed! [sm=smiley32.gif]
Old 11-15-2008 | 03:42 AM
Anubis's Avatar
ORIGINAL: Fast951
Yea, that's what I thought... But it isn't sparking. And the starter sounds fine :-/ I could still get it tested just to be sure though.
PorscheDoc... I'll check that out, thanks.
Old 11-15-2008 | 05:20 PM
I would also replace your DME relay at the same time, as it can cause issues like this.
OnesickCarreraGT
05-29-2008 03:06 PM
84944s
03-16-2008 03:27 PM
bepinlv
06-16-2006 04:06 PM
pjc944
05-09-2005 06:38 PM
Mattrf
10-15-2004 09:39 PM
