944 engine sound
944 engine sound
Hi,
I have an 86 944 na, automatic. There is a rattling sound coming from the rear of the engine when at idle sometimes or when you have it in gear at a light, not moving, the minute you give it some throttle it goes away, its not anthing on the exhust. Any idea?
Thanks
Eddie
Thanks
Eddie
hi,
Put it up on the lift, sounds like its coming from the center shaft, only when at idle and in gear (its automatic). The minute you take it out of gear or you give a little throttle the sound goes away. It sounds like a rattle/vibration noise. Anyone have a suggestion?
Eddie
Eddie
