944 running hot
944 running hot
my bro's got an '87 944 S that always runs hot. funny thing is, the expansion tank feels cold, even when temp guage is almost in red.
I'm thinking water pump, thermostat??? ... hope it's not water pump.
any suggestings on diagnosis/running cooler?
Thanks!
Thanks!
RE: 944 running hot
Have you done any work on the coolant system that would cause air in the system? If you are losing coolant, and there are no visible leaks, you may want to do a leakdown and compression test, as you might have a bad headgasket.
