Engine mods to a 84' 944?
Old 04-19-2006 | 05:36 AM
hmmhoyhoy's Avatar
Default Engine mods to a 84' 944?
Hey guys Im ripping my engine apart soon to fix a problem that Ive got. I figure I could do some engine mods while the engine is apart, or close to bein apart. Im not lookin to spend a whole lot of money, but what kind of stuff can I do while everything is torn apart? Thanks.
Oh and is it possible to bore out the throttle body without getting a new butterfly? Any other mods I can do that wont cost me a bundle as regards to everything else? Im new to Porsche all together so Im not so knowledgeable in this department.
Old 04-19-2006 | 12:04 PM
Default RE: Engine mods to a 84' 944?
Not a lot you can do to an NA for power. You could cross drill and balance the crank which will help the engine run a bit smoother. Other than that, have fun in the corners, and when you can, upgrade to a 944 Turbo.
Old 04-24-2006 | 02:42 AM
Mr Pilkington's Avatar
I have read before that you can swap for the 968 Crankshaft and rods to increase stoke. Call some of the salvage locations and I am sure you can locate a decently priced unit.
I prefer DC Automotive
Other than that most of the mods for any 944 are tremendously expensive.
I know speedforce has some very nice fuel management, but the gain per dollar spent is insanely low.
Old 04-24-2006 | 12:37 PM
ORIGINAL: Mr Pilkington
Properly building a 2.8L Stroker is extremely expensive. You will have 10k in the motor very easily.
Old 04-25-2006 | 07:49 PM
PorscheUniverse's Avatar
I think you should do all the basics while you can, belts, pulleys, air filter, fuel filter, ect..
Old 06-07-2006 | 06:26 AM
backyard_engineer's Avatar
Port and polish. And besides, it's a fun and educational thing to do. Its the best gain/$ thing to do. I have a spare head laying around right now that I want to port match/polish etc, and mill the surface to increase compression, just for kicks. Have no idea if it will work though!
rapidstu
03-06-2009 03:23 PM
LUVA996TT
05-16-2008 09:36 PM
crazywill
08-04-2007 04:56 AM
nelsonjohnson
11-01-2005 10:27 PM
count
01-07-2004 03:22 AM
