Heater Problem
Old 01-23-2007 | 04:19 AM
Easy944's Avatar
Default Heater Problem
I know youve probably seen this problem before but...my car has just recently been blowing only hot air, especially at higher speeds/revs like on the freeway.Even when the vents are shut and theair is off, hot air still seeps in! SoI talked briefly w/ a friend at Brumos (local Porsche Dealership) and it may be a plastic clip on the heater control unit (He gave me a small plastic plug/clip).Just wondering where it is and if there are any other possible problem areas...Thanks in advance!
~James
Old 01-23-2007 | 12:35 PM
Default RE: Heater Problem
Look down on the side of the unit (drivers side footwell)
Old 01-23-2007 | 12:58 PM
Easy944's Avatar
Thank ya kindly Doc! Hopefully that will fix it...
Old 01-23-2007 | 01:46 PM
Panzer's Avatar
when you say plastic clip are you talking about the tempature potentiometer that controls wether it blows hot or cold air? I'm having the same problem but I just need a new heater valve.
Old 01-24-2007 | 01:26 AM
Easy944's Avatar
Yeah thats exactly what I was talking about...sadly that didnt fix it so I guess it could be the heater valve or something else...
Old 01-24-2007 | 12:46 PM
Check to make sure the vacuum line is connected to the heater control valve and the firewall.
Old 02-10-2007 | 06:47 AM
944turb0's Avatar
I ahve the same problem...waht happened to the other thread?
stv
07-19-2020 04:07 PM
hadakaneko
02-20-2010 11:53 PM
speedmonster_fia
07-08-2007 02:26 PM
99silver911
09-03-2006 02:11 AM
bajabubba40
07-15-2005 04:52 PM
