Milling the head
RE: Milling the head
Octane change will do absolutely nothing unless you alter the cam timing, and move the pickup sensor plug on the flywheel (both would require extensive modification).
Even milling the head you are not going to notice much change in performance. The NA motors are what they are. You will spend a lot of money trying to get any additional hp out of them.
So your saying leave well enough alone... lol. I get that, just thought i'd try and mess with the new 84 which needs a head gasket and other minor things.I'lljust get it to factory specs and let er ride...thanks.
