Need Help ASAP
Old 06-03-2006 | 06:30 PM
oso1000's Avatar
Default Need Help ASAP
Hey guys. New to this forum and I need a little advice. I am looking at buying an 84 944 with 180k miles. BOdy and interior are clean but owner says the timing belt is broken. How mush would you guys say is a good deal for this? What kind job am I looking at with fixing this problem? ANy help is greatly appreciated. Thanks
Old 06-03-2006 | 07:44 PM
Default RE: Need Help ASAP
Less than 500 bucks. If you don't do the work yourself, you are looking at a 2-3k bill depending on the damage to the valves to get the car running again. This is to properly do everything you need to do while you are in there.
Old 06-03-2006 | 07:48 PM
To expand on this:
Cost of parts:
Figure a minimum for 4 bent valves (sometimes there are more, sometimes only 2-3): Figure $60-70 per valve
Waterpump, belts, rollers, front seals, valve guides, etc: $450 give or take
Head work, install guides, valves, work the head: Minimum $200-250
Labor: 13 hours to remove and replace the head. Another 3-4 hours to do the waterpump and front seals.
thomasdean932
04-23-2014 06:55 AM
jagboy
02-09-2008 08:40 AM
twitchy
11-14-2006 07:30 PM
Gettylee
07-07-2006 08:07 PM
hdcivicracer07
03-18-2006 06:03 AM
