Next question... rear drive shaft boot replacement????
Hi all,
Right, I've fixed my door handle, the next job on my 944 S2 fix list is.... changing the inner rear drive shaft rubber boot. Has anyone got any good tips on doing this job? How long (est) does this take and is there anything I should replace at the same time?
Thanks in advance.
Thanks in advance.
RE: Next question... rear drive shaft boot replacement????
Hmmm havent had a 944 axle apart in a long time, but usually there is a spring clip you have to undo, then the joint itself can come off and you can replace the boot. Just remember to grease up the joints really good.
WolfgangCarCare
05-19-2015 05:25 PM
