Ooops I dropped the lifters! Sorry CAM Followers
Old 10-08-2008 | 03:22 PM
Speeddreemin's Avatar
Default Ooops I dropped the lifters! Sorry CAM Followers
I was taking the head off my car the other day because I broke a timing belt/bent valves. Anyway, The head was sticking, and didn't want to come loose. When I pulled, it jerked upward and most of the cam followers fell to the floor. I visually checked out the wear on the followers and on the cam lobes, and didn't really notice any signifigant wear patterns on either. The engine has about 107,000 mi. What would be the odds of me being able to put the followers back in, but NOT in the same order they came out?
Old 10-08-2008 | 09:53 PM
Fast951's Avatar
Default RE: Ooops I dropped the lifters! Sorry CAM Followers
It doesn't sound like you have much of a choice. If it's of any comfort, you are definitely not the first person to do this.
Old 10-09-2008 | 11:34 AM
You don't have to put them back in the same order. It is nice if you can, but not necessary by any means. Just make sure the followers are nice and stiff, you shouldn't be able to push in the metal button in the middle.
Old 07-08-2010 | 11:30 AM
rwalkertx's Avatar
Default Cam Followers ?
I removed the cam shaft section to pull the head and half of what I would call the lifters fell out, they seem to be ok but are not in the same locations anymore are these what you refer to as cam followers?
Thanks
Old 07-08-2010 | 01:04 PM
Yes, it is technically a "cam follower" and not a lifter. A "lifter" rides on a cam and a push rod sits in it, which drives your rocker arms to open and close valves on a different design of engine.
NONNIEMYERS
06-14-2010 08:04 PM
carqeek
09-20-2007 09:09 PM
BIBBER
06-07-2006 11:34 AM
g60sam
04-25-2005 11:50 PM
Lloyd
03-03-2005 09:32 PM
