Overheated Engine, Cool Radiator
Old 09-07-2007 | 09:33 AM
Default RE: Overheated Engine, Cool Radiator
ORIGINAL: chelle26
check this one, http://www.aa1car.com/library/overheat.htm
Engine overheating problem might be from radiator cap and the pressure it holds. If the radiator cap does not hold pressure correctly then coolant could boil and therefore the engine would overheat. Another reason might be caused by thermostat failures; it is recommendable that you check. And coolant leaks such as those from the porsche radiator, the hoses, the water pump, the freeze plugs or any others. Also, problems in the water pump could be the cause and therefore you should check it and replace it in case it is needed.
He already said the waterpump pulley is not turning with the engine, so it is seized and is the problem.
shawnbem
07-29-2015 05:42 AM
JustinFanatic
03-26-2013 02:08 AM
funai
05-25-2008 05:01 PM
marc7388
05-23-2007 01:13 PM
Olaf
09-11-2005 12:16 AM
