Quick fuel pressure question
Old 05-19-2009 | 07:33 PM
ppwcanada's Avatar
Default Quick fuel pressure question
I have a 86 944t. I have an no start issue. I narrowed it down today. I sprayed a bit of starter fluid in and it fired. I had removed the end nut on the fuel rail a few days ago and spun the engine and a gush of gas came out. I tried it again today and nothing.
Would that be a fuel pump or fuel pressure reg issue...or? Thanks!!
Old 05-19-2009 | 08:06 PM
ppwcanada's Avatar
Just remembered something important. When i got my gush of gas out of the rail, i had a jumper on the DME relay, on spots 30 and 87b (i believe). BUT when i tried to start it, nothing. I couldn't get a reading on the pressure as my fuel pressure gauge had the wrong end to screw on. But it does fire with starter fluid...
Old 05-20-2009 | 12:10 AM
If it has fuel with the relay jumpered, then you might try replacing the DME relay. Fuel pressure should be 36 +/- 3psi.
tombradberry1
07-16-2013 07:47 PM
hadakaneko
07-18-2009 02:43 AM
Justice
02-05-2009 09:49 AM
namv
06-29-2007 12:49 AM
dwhita6605
04-08-2007 04:49 PM
