recharging air conditioning..
Old 05-08-2007 | 09:16 PM
auhsojknig's Avatar
Default recharging air conditioning..
its starting to heat up fast and i need to get my freeon (spelling?) recharged. where can i get this done at? will somewhere like pepboys do it?
Old 05-08-2007 | 10:45 PM
Default RE: recharging air conditioning..
You will need to find someplace that charges R12 still. R134a started in the early 90's, when it replaced R12, so those old systems are becoming few and far between. The problem is if your system is empty, they will have to jump the compressor clutch to get the freon moving. The low pressure switch will not activate if there is not enough freon in the system. Also, freon does not just disappear. If it is gone from the system, that means you have a leak somewhere and should fix that first. Get dye injected into the system and locate the leak. Hopefully it is just an o ring somewhere. Then get the system filled.
I would recommend taking it somewhere that is familiar with Porsche AC systems.
Old 05-09-2007 | 01:14 AM
auhsojknig's Avatar
ok thanks alot.. thats is really helpful. i will definitly research that..
1995AJR993
09-06-2007 01:34 PM
hummitz
08-30-2007 05:51 PM
BayArea
08-17-2007 04:14 PM
99silver911
09-03-2006 02:11 AM
jlb532
06-14-2005 01:07 AM
