Reference/Speed Sensor
Old 09-30-2008 | 02:34 PM
hemimike's Avatar
Default Reference/Speed Sensor
Normal 0 Are the “reference mark sensor” and the “speed sensor” the same part / part number? They appear to be the same. I broke the “speed sensor” during the clutch removal process. I have found several sensors that are called “reference / rpm” sensors. I believe both these items are the same part and just supply different information to the car. The part is too expensive to make a mistake. Thanks, Mike
[IMG]local://upfiles/7284/59B1C45198ED4CBC816A281CB8095E34.jpg[/IMG]
Old 09-30-2008 | 11:04 PM
Default RE: Reference/Speed Sensor
Yes, they are the same. BMW uses the same sensor and it is a lot cheaper (at least half the cost), with the only difference being it has a longer wire, as their sensors are mounted lower on the bellhousing. IIRC if you pick about an 86 3 series, you should be able to find it.
AJB85944
01-30-2009 10:04 AM
RATNIK
08-04-2007 06:41 PM
ppwcanada
07-30-2007 10:26 PM
onrails
12-30-2005 12:45 PM
foz
12-16-2004 07:11 AM
