Removing air cleaner for better intake air flow
Old 12-25-2004 | 12:37 AM
944-Pilot's Avatar
Default Removing air cleaner for better intake air flow
The stock induction system seems kind of strange; the air has to do a lot of twists and turns and the stock air box is kind of restrictive, so I just deleted it. What a difference! My ride sounds so phat now and it goes faster, probably some from the better air flow and some from the 10 pounds less weight! You should all do it, just thought I'd share!
Old 12-25-2004 | 12:58 AM
Macfreak007's Avatar
Default RE: Removing air cleaner for better intake air flow
FREE YOUR ENGINE! DUMP THAT AIR CLEANER!!!!
I mean big rocks and stuff wont fit in there anyways, whats the point of a filter???
Old 12-25-2004 | 01:01 AM
Not Danno's Avatar
You guys are idiots! Don't you know that a big phat K&N filter is more free-flowing than no filter at all? I mean, it's got negative restriction!
Old 12-25-2004 | 01:58 AM
84carrera944's Avatar
toujours supprimer l'air laveuse parce que souillé aérer s'écouler plus rapide que air pur et le c'est aussi mieux pour votre essence usage
Old 12-25-2004 | 10:52 PM
theedge's Avatar
ORIGINAL: Not Danno
Its the first step to forced induction, those K&Ns actually force some air into your engine.
ONE PSI BOOST BIATCHES!!!!!!!!!!!!!!!!!!!!!!!!!!111
Racerx80
04-04-2010 03:42 PM
tjmisch
01-15-2008 05:20 AM
ls911
10-31-2007 12:51 AM
Skywalker
10-12-2007 06:51 PM
rpmirage
10-08-2007 09:15 AM
