Steering Vibration - Help!
Hi
I have a 1989 944 Lux owned from new.It is only used very occasionally and has coved 38,000 miles.Recently I put on a new set of reburbished Design 90 wheels and new tyres. The wheels were balanced andtracking was within tolerances.
In normal city driving the car is fine, but, when the speed reaches above 40mph, the steering wheel vibrates harshly. If I increase speed to 50+ the whole car starts shaking.I checked the wheel balance and tracking agin and they are fine. Does anyone know what the problem is? Incidently, thewheels came from a 944S2 which has a front wheel offset of 55. The spec for my model is a 52 offset. Can this be the problem?
Many thanks.
Many thanks.
RE: Steering Vibration - Help!
Hi Doc
The problem with the vibration was caused by a seized front brake caliper. Whilst investigating the technician also found 3 of the 4 new P6000's were out of shape. After the caliper was cleaned up and the old tyres put back on, the car is as good as new again.
My front brake disc has discouloured from theheat. Will this cause a problem in normal driving?
Thanks again
Thanks again
