weird die at idle
weird die at idle
Hi all
So I've had a 86 944NA for about a year and this is the first problem I've had. I'm driving along just fine, its a cold foggy day, I get to a light in town and the car just dies. I hear a small click and then it just dies. It would turn over, but it seemed like either no spark, no fuel, or no signal to the injectors. I try jingling the DME relay, no luck. I eventually got it started after letting it sit about 3 hours, my mechanic shows up and it start right away no problem. So how on earth would I track this down or is it perhaps just a freak occurence and was perhaps fixed simply by jiggling a couple fuses and the DME relay? What things can I look at or perhaps connection to clean that might prevent this from happening in the future? If it helps any it seems that the idle was a little rough today before it happened, and still seems a bit rough (though its possible I'm jsut being extra aware of things now)
Any ideas?? Other than this I;ve had nothing but joy from thsi car
Garen
[align=left] [/align]
Garen
RE: weird die at idle
Ok I have a new relay in the mail. I was wondering though, why is it that this part fails so often. Is it a problem with the part overheating. WOuld that explain why the car would then start again hours later?? Just curious. Thanks.
wholesale8
10-05-2012 02:29 AM
SpeedChannel
03-21-2008 02:01 PM
