whine sound from firewall area
Old 10-02-2009 | 08:56 PM
nankipoo's Avatar
Default whine sound from firewall area
1988 944 NA Auto Trans
Right after a rain a sudden whine sound starting coming from firewall area. It Will NOT make the whinning sound if on jack stands. Sound is at all speeds but increases at decelerating. No recent water leaks.
I just completed putting motor back in after assuming pilot bearing (did not go by pulling trans, long story there) anyway same sound is coming from front and center of car. Wasted alot of hours it seems.
When motor was out I thought I had found the problem because the pilot shaft bearing had been spinning on the shaft and had worn it down a little. It looks like the pilot bearing was very stiff and caused the spinning. I built up the shaft and put in a new correct bearing. I also spun, pushed and pulled the shaft, no slack was felt.
Any other Ideas.
__________________
Lowell
Old 10-03-2009 | 10:52 AM
Did you replace your throwout bearing?
Old 10-04-2009 | 10:19 AM
nankipoo's Avatar
yes new bearing
Old 10-04-2009 | 11:14 AM
So did you put in an entirely new clutch, or just replaced both bearings?
Old 10-04-2009 | 06:02 PM
Beverly Stayart's Avatar
Were both bearings replaced?
SICAYENNE22
09-14-2009 07:40 AM
two911s
10-02-2005 11:24 PM
BradS911
05-17-2005 07:08 PM
larkstar
12-28-2004 03:01 AM
larkstar
01-03-2004 01:49 AM
