Boxster 2001 Brake Lights not working
Old 12-11-2008 | 03:38 AM
asz88's Avatar
Default Boxster 2001 Brake Lights not working
HI i have boxster 2 2001 - all brake lights not working suddenly - bulbs replaced and fuse ok.
Any suggestions - could it be the brake switch in which case how should i check and fix
Thanks
John
Old 12-11-2008 | 11:32 AM
Default RE: Boxster 2001 Brake Lights not working
Brake light switch is probably bad. Only takes a few minutes to change and is about 20 bucks. Locate the brown/black switch down by the brake pedal (it has a plunger on it), and twist it 90 degrees then remove it. Pull off the electrical connector and then replace with new.
Old 12-12-2008 | 09:08 PM
asz88's Avatar
Thanks so much DOC
Worked perfectly and all up only cost me $26 AUD.
Cheers
tinchao
02-16-2007 03:44 AM
bajaracer
10-24-2006 12:38 AM
trustinme80
09-28-2006 05:51 PM
vanvreede
09-05-2006 07:12 PM
