Boxter Remote Key Problems
Old 11-30-2009 | 04:41 AM
asz88's Avatar
Default Boxter Remote Key Problems
Can anyone help?
Boxter Remote Key problem: I note that my remote key is struggling to work and only after many attempts. This happened to my other key and hence I started to use this remote key which was fine for a while but now same issue. With a fresh battery it was ok for a few weeks also.
Have tried the following:
Fresh battery , checked that not in sleep mode, and have resynced the codes by using the remote within 6 seconds of key in and key out of ignition, reversed polarity of battery also.
HOWEVER : i have found that both keys work perfectly if I open the remote casing and use the remote out of the casing.
Any suggestions
Thank you
cmilam
03-23-2008 07:08 PM
jcturner6504
12-15-2007 06:35 PM
jimmie325
07-03-2007 01:56 AM
jimmie325
07-02-2007 12:15 AM
normanteozw
06-30-2007 05:34 AM
